leaking oil around pto shaft
John Spinney
New User
hello I have a 1956 massey harris 333, it is leaking rearend grease around the pto shaft. im guessing I have a bad seal,what im wondering is if If I can change the seal without going inside of the rear end.if If I take the 4 bolts out of the housing will the pto shaft pull out or is the something inside holding it .thanks for any info you can give me on the matter
