Anonymous-0
Grand Pas old 1965 MF 165
Sat for a while, when I got it everything except pto clutch seemed to work ok (didn't use much) but when I was using a sub soiler it wouldn't pull it back out of the ground... After I got it out, only the draft control lever would work.
I decided to split / put mew o-rings in the pump/ stand pipe. Also put 2 new clutches in...
Got it back together and the draft control still works but won't hold much weight.
Lift works kind weird. It will do nothing without draft control. If DC is half way up the quad, the lift will move the links up slowly after u pass the DC lever and will lower the links if u go back down below the DC lever.
I did not put a new pressure relief valve in. Could that be the problem?
It's a multipower tractor but the MP pump is unhooked (was when I took it apart). Also the stand pipe orings (new) wasn't as wide as the old ones (one old one was so bad it fell apart when I took apart). Even the squeeze out wont make them as wide as the old one but the diameter fit tightly into the pump, the upper didn't seem to fit as tight into the diverter valve housing.
All info greatly appreciated
