2 spool valve
rfridy73
Has anyone had the problem? I was runnin the loader on one of the valves,all of a sudden one day the loader would just barely work.Changed to the other valve it has worked fine since.I forgot to say its a factory two valve on a 255.Checked it out today the other does not have any pressure at all.Has anyone been into one of those valves?
should be able to look up the valve on agco parts book guest user the drawing my help,i think the valve only has one relief for both spools so that rules out a bad relief,check to see if the lever is moving the valve spool, does the detent hold the lever in position or does it return to neutral on it's own,if the lever moves the spool and stays in position without the detent plunger returning it to neutral then you will have to disassemble the valve and look for a damaged spool or a land broken off inside the housing both of which are rare problems, hopely it's something simple
