65 deisel with loader
2tractors
I gave the 65 a small workout today and found what looks like blowby coming from the air intake tube where it meets the hose which is missing a clamp. Where does one measure the compression on a deisel?Here's a before an after.
A local shop built a compression tester gauge with a end of a injector so he could screw the gauge on it and into head. Then he tested each cylinder. Works fine. Just had to have a way to connect it to head. Just use a old injector and make one.
Looking in good. Did you get your p/s figured out? The p/s on mine is leaking on my 65 now. I've got to rebuild it. Got any advice? The steering on my 180 quit as well.
Thanks Miner.Brendon the only problem with rebuilding the steering sector is laying out over 60 bucks for several small pieces of rubber, my suggestion is to take out the seals and get them matched at a bearing and drive business. Mine doesn't leak now but left turns are brutal, got to adjust.
