101 JR RC single front wheel?
OldIron
Hello,
I have a Massey 101 Jr RC with a single front wheel system.
I'm looking for a seal kit for the gearbox, as it's leaking fluid and before I take it apart, I'm curious if one exists or if I need to make them all as I go.
Also, what sort of bearing/seal keeps fluid from coming through the 'swivel' steering point?
One last silly question: The steering u-joint is a bit tired, and I'm curious how I remove the universal from the shaft. It looks like a pin in there, but drift punch hits didn't reveal any movement.
Thanks
OldIron
Wedge something solid between the frame and U- joint to eliminate the bounce in the shaft. Drive the pin out in the opposite direction that it was driven in, if you can determine that. You may need to use an air hammer. New U-joints are available.
Thanks Wayne!!
I'll try that this afternoon.
Are they rebuidable, or simply buy a complete u-joint assy?
Russ
