Leaky Boot
Looking for info on above tractor. Neighbor is thinking of buying one and doing some research for him. I looked it over and it looks like a basic MF 135 with a 3 cylinder gas. The backhoe has the rotation cylinder to swing the boom which I read is very hard to get parts for. It did not show signs of leakage so the hope is it will be touble free for sometime to come. Has anyone had luck repairing the rotation cylinder on these lately? Am I correct that most 135 parts will fit the tractor?
The exhaust pipe looked like an 8N Ford horitzonal pipe that was rigged up at a strange angle. The manifold was a bottom outlet. Did the original go down under the tractor or did a pipe make a 90 degree back up with a muffler on top?
Another issue: There are 3 point top lift arms and a PTO but owner says neither worked the 1.5 yrs he as had it. He thought maybe they were "turned off" or something. Any ideas on this? Someone said the PTO was Hyd. operated and the pump might be bad. Any truth here?
One more----the power steering cylinders have a ball tie rod type end which seems pretty worn. How is the best was to repair this as they were welded onto the cylinder rod.
Thanks, LB
Thanks, LB
