robilmichael
Hi, I ordered the sealing ring (nitrile) and the rubber o ring on the new 3 1/8" hydraulic ram on a MF135. The sealing ring is the size/width of the groove in the piston. How are they installed? Does the sealing ring get installed first and then the rubber o ring on top of it? How do you expand the nitrile sealing ring as it is way too small to pry over the piston and it is very hard? I tried putting it in boiling water and now got in on the piston but it will not shrink in size to allow the rubber ring to be installed on top of it.
Thanks.
Thanks.
