MH44 air cleaner hose
David G
I want to get a replacement hose for the air cleaner at the auto parts store. It is a 2" 90 degree hose.
Does someone have a part #?
I don't have a part number handy, but I replaced mine a few months ago and just got a piece of radiator hose with a 90 degree bend in it. We just matched it up to what was hanging there in the store. BT
NAPA # FM61 is a flex hose with the ribs, it's 2 x 14 1/2 inches long, will fit right on. If you like a smooth hose NAPA # 7372 is a pre formed hose, have to cut a little off one end.
I have been struggling with hooking up the air cleaner on the MH44 EFI. I finally figured it out last night.
The throttle body OD is 1.5", I am going to put straight piece of 1.5" radiator hose on it so that shims up to 2". I will then use a 2" 90 on the air cleaner, and one on the throttle body, with a straight stainless piece between them.
Upper radiator hose of an 89 Dodge W250 with Cummins is close. The bend is sharper than the factory curve, but the hose will fit with a slight trim. The last on I did got a 90 degree mandrel bent exhaust pipe and two small straight pieces of hose. If you didn't know, you'd think it was factory...
