Roger Missildine
Hey folks, back again with an update and question.
Got the engine pulled out of the tractor, disassembled, and have begun some cleaning. While investigating the low oil pressure / #1 rod bearing spinning and trashing the crank, I took the oil pump cover off to check the gears. It had quite a bit of thrust play in the shaft prior to taking the cover off. Hopefully the picture will upload and you can see what I discovered.
I don"t think the cover is useable anymore. Anyone know where I can find a rebuilt, or rebuilable pump?
It"s the Continental Z134 gas engine.
Thanks for your help,
Roger
Roger
