MH 44K Tranny Question
Sapper55
Gentlemen,
I am in the process of filling all fluids in my "48 MH 44K. I am not sure which is which when it comes to the transmission. How do I tell if I have a tranny with a pump attached to it compared to a standard version (no pump)? I have an RC tractor. I appreciate your response(es).
Regards, Sapper
Early 44s had an oil pump in the rear end not the transmission. It will not have anything to do with you replacing the oil. You should use 140 weight rear end oil as it is a closer viscosity to the old 90 weight.
Tom
