Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: MF155 (Perkins AD4.203) - new fuel lines/parts?
DavidP, South Wales
07-21-2014 01:15:39
Re being stuck in reverse;
Remove the oil filler plug next to the gearlever and using a flashlight look inside. You will see the three selector which slide back and forth. The problem is most likely to be that the reverse one (the one on the right hand side will be in the rear position and possibly the gearlever has become disengaged. Using a suitable screwdriver or 10-12mm bar prise the selector back into the middle position to give you the neutral gearlever position.
With 8000 hours there is likely to be major wear on the main gear lever pivot pin. Can you turn the gear lever at all? Is there excess up and down movement? This is normally the cause if these tractors becoming stuck in gear. If you are able to free the selector it is good practice to make a point of pushing the gearlever downwards every time you change gear. This minimises the chance of it disengaging. The only answer is to replace the pivot pin and possibly the gearlever.
