Brian Young
New User
Wondering if a few of you guys can advise. Looking at a 180-can't engage engine PTO, and when trying to engage ground PTO with clutch fully depressed, it grinds and won't engage. Also, can't shift 3 speed or HI - Low without fully depressing clutch to the fully depressed (to the floorboards) position. When releasing the clutch, the tractor started to drive as soon as I started to release from a depressed or disengaged position. And, backed the tractor up a gradual incline-when I stopped and tried to select a forward gear, it seemed there was still tension on the drive train...with the pedal fully depressed I had to tussle with the shift to make it shift.Now...to get things in order-does anyone know if this is a simple adjustment or possibly a pump problem. The seller told me the clutch had been recently replaced. Many thanks in advance!!
