Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Stuck in 1st gear
MF rules
07-19-2014 23:58:14
It still might be stuck in first gear even tho the shifter lever is in neutral. With the engine running and your foot disengaging the clutch put the lever back into first gear again and drive a couple foot ahead in that gear then try other desired gear. Also make sure hi/low lever is in either hi or low.
If none of the above works then you might have to remove your foot accelerator pedal and check for dirt build up under linkages that can restrict movement of levers.....also may need to adjust linkages???
