Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Massey 1085 PTO clutch
07-18-2014 15:41:50
From your description, it sounds more like your aux pump is getting weak. I would first check the pressure of that system, sounds like the pressure is dropping when the oil warms up and the clutch pack can't keep up with the load. You will still have to remove the lift cover and split the tractor aft the transmission. This is assuming that you have IPTO system, meaning that you don't have 'Ground PTO' on the pto lever. HTH's lee
Just looked up your system and it looks like the same as my mf 165, if you have multi-power, you could also have some slipping in high, as that uses the same pump and pressure.
If I had your email I could email you the procedure from the Clymers manual.
This post was edited by lee231 at 15:58:05 07/18/14.
07-18-2014 18:09:30
 Re: Massey 1085 PTO clutch in reply to lee231, 07-18-2014 15:41:50
Lee231 my email is
Thanks for the info I really appreciate it! This will be a big help.
I just hope I can get it fixed up before I gotta do second cut.
