Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: MF135 lift cover removal to fix lift piston rings and ti
07-17-2014 10:56:58
6" long will be plenty, after you cut the heads of the bolts off you can grind a little taper on top.
Take your time to position the tractor under the pulleys you have as close to center of the cover (side to side) as you can. You can roll the tractor back, or forth a little bit to get the cover to lift up as straight as possible (you will be favoring the rear of the cover more than the front).
