TractorLinks.com
Show Parts for Model:
Massey 1085 PTO clutch
GFF
07-16-2014 17:20:22
My massey 1085 diesel pto has seemed to be slippin when under a load. It seems to get worse as it gets worked longer. it works good at first and as it gets used all day mowing/baling it bogs down. im guessing that the pto clutch is worn b/c my baler and mower are small enough that this shouldnt happen and it has run then with no problem in the past. I was also wondering does anyone know if it have to split the rear end to change the pto clutch or an it be replaced from just removing the pto shaft from the back?
thanks for your help!
lee231
07-18-2014 15:41:50
 Re: Massey 1085 PTO clutch in reply to GFF, 07-16-2014 17:20:22
From your description, it sounds more like your aux pump is getting weak. I would first check the pressure of that system, sounds like the pressure is dropping when the oil warms up and the clutch pack can't keep up with the load. You will still have to remove the lift cover and split the tractor aft the transmission. This is assuming that you have IPTO system, meaning that you don't have 'Ground PTO' on the pto lever. HTH's lee
Just looked up your system and it looks like the same as my mf 165, if you have multi-power, you could also have some slipping in high, as that uses the same pump and pressure.
If I had your email I could email you the procedure from the Clymers manual.
This post was edited by lee231 at 15:58:05 07/18/14.
GFF
07-18-2014 18:09:30
 Re: Massey 1085 PTO clutch in reply to lee231, 07-18-2014 15:41:50
Lee231 my email is gibaldifamilyfarm@gmail.com
Thanks for the info I really appreciate it! This will be a big help.
I just hope I can get it fixed up before I gotta do second cut.
Dieseltech
07-16-2014 19:32:23
If I remember right the lift cover must be off, and a split at the trans-diff joint, so the three point pump can come out before you can get to the clutch pack.
