ok folks , you guys have helped me out before so here we go , I looked at a massey 1030 compact 4x4 tractor. when the owner purchased it the clutch was shot. He had the clutch refaced , the flywheel turned to clean it up, new throw out bearing, reused the pressure plate , he said the pressure plate is not available. this is a two stage clutch and he drove it into his shop on the revits to get it tore down. Now with parts replaced as mentioned above the tractor will not move.pto works but no tractor movment he has adjusted the bolts on the pressure plate in both directions and changed free play in the clutch pedal in both directions with no change still no movement. Anyone have specs as far as flywheel thickness or any ideas as to what could be going on with this thing. any ideas are welcome! Thanks guy"s
Untitled URL Link
Untitled URL Link
