TractorLinks.com
Show Parts for Model:
Re: Fix for transmission shifter?
gbs
07-13-2014 13:07:19
not that familiar with 202 but most mf that size have a spring under the shift lever to hold it down it could be broken,but to solve the problem your having I've had to replaced the shift rail stop bar on 2 of our tractors that wore thru after years of the shift rail hitting against it, only replaced 1 spring retainer on another mans 135,bad part is to replace the rail stop the trans. has to be separated at the rear end joint the spring is not to bad depending on how the trans. top cover is mounted
