My 202 has the problem of the shifter getting stuck in 1st or reverse and I have just dealt with it by taking the top plug out and moving the gears with a long screwdriver. It happens mostly when I accidentally pull up on the shifter while moving it but on a long day it can happen 4-5 times.
I just noticed there is about 3/8" of up and down free play where the pin goes through at the base. If I remove the pin will all h*ll brake loose? I was thinking maybe I could eliminate some of the movement and keep the shifter from coming upwards and dislocating.
