TractorLinks.com
Show Parts for Model:
Re: Massey 135 Front axle pivot issue / bush replacement
DavidP, South Wales
07-11-2014 01:42:29
Hello,
Yes, there are two pin types for the front axle on the later 135.
1869 633M1 is up to s/n 434523 and 1869 634M1 is from s/n 434523. I have a recollection that the difference is in the length of the pin.
If you have basic tools and a safe means of supporting the tractor then there should be no problem. Once you have the new bushes and pin the cost of having a drift machined would be a simple job. Do you know anyone who has a hobby lathe in his garage? It's worth doing to make sure you don't damage the new bushes. If you need to make a puller then I or someone on here will talk you through it and show you what is needed. A worst case scenario would be that you can't remove the pin and have to take the beam and casting assembly to someone who has a suitable press....tractor dealership etc. If all fails then you should be able to hacksaw through the pin on both sides of the beam (don't think it will be too hard) and remove it that way.
With the bonnet, radiator and locking pin removed give the pin a few 'exploratory' wallops
with a heavy hammer or small sledge to see if you have any movement. If you do, you are halfway there!
Cheers
DavidP
Pacer204
07-14-2014 15:11:19
 Re: Massey 135 Front axle pivot issue / bush replacement in reply to DavidP, South Wales, 07-11-2014 01:42:29
Hi David
Thanks for the advice, I'm going to give in a go! Will report back and may attempt a boring video!
Thanks to all for the advice- much appreciated.
Richard
