stampede
New User
Everything worked great and I let a friend use it and it was returned and nothing worked as for as hyd. is concern. Can anyone give me advice? All levers are in correct position.It was low on fluid
and I told him it needed fluid. It was full when returned. Can anyone help?
I don't loan out my tractors or my wife. I've found that most borrowers don't give a s--t about what they borrow. IMHO
2 stage clutch?
Does your PTO work?
My first thought is the PTO clutch is toast, therefore not turning hyd pump.
(quoted from post at 02:41:28 07/09/14) 2 stage clutch?
Does your PTO work?
Dear 495man.
PTO still works great. Disconnected several steel lines and no fluid
is present when engaging levers. All help is appreciated. Thanks Chuck
Does it just have a single hydraulic pump, or the 'piggy back' aux. pump as well? What did the 'friend' use it for? Does the 3 point arms just go all the way down and stay down? Has the hydraulic strainer in the bottom of the hyd. sump ever been changed?
My 253 needs the strainer changed right now. It has about 1,500 hours on it, and a light is coming illuminating on the inst. panel showing, I think, low hyd. pressure.
Garry
neighbors 175 done the same thing and the steel line that connects the aux.pump to the housing fitting had worked loose and one end came off pumping the fluid back into the case
(quoted from post at 02:57:40 07/10/14) Does it just have a single hydraulic pump, or the 'piggy back' aux. pump as well? What did the 'friend' use it for? Does the 3 point arms just go all the way down and stay down? Has the hydraulic strainer in the bottom of the hyd. sump ever been changed?
Garry
Garry
Only know of single pump. Friend said used it to move some dirt.
Three point hitch is down and won't do anything. Strainer has not been changed but no hyd anywhere. Please help and thanks for
your inform. Chuck
