TractorLinks.com
Show Parts for Model:
Re: Massey 135 Front axle pivot issue / bush replacement
ptfarmer
07-09-2014 14:01:44
With the straight axle the pivot has a pin that keeps it from rotating in the axle. The axle support that bolted to the front of the engine has a bushing on the front, and back of the axle support. On my 2135 Industrial tractor it has a similar setup, the rear bushing in the front axle support was gone, and the pivot pin wore into the front axle support itself about 1/8". I have welded up the worn front axle supports, and re-bore them to take a new bushing on a few Massey Fergusons (one going on 25 years now with no problems) just make sure you keep the new bushings greased. I like to give them a shot of grease along with the spindle bushings every day before using it (I've welded up, and re-machined a few spindles where the bushings ride on the spindle). Consider yourself are lucky it didn't wear through the bushings, and I'll also bet your spindle bushings are worn out also..
