TractorLinks.com
Show Parts for Model:
Re: MF 290 Fuel Bleeding Issue
jogl
07-08-2014 02:49:00
Keep bleeding and checking for loose connections. The new filter is sealed up properly, right?
LJS30
07-09-2014 12:27:36
 Re: MF 290 Fuel Bleeding Issue in reply to jogl, 07-08-2014 02:49:00
Everything is tight without leaks it seems. I tried again this morning and no luck. I got it to start once but it ran for about five to ten seconds then shut down. What am I missing!?!??! :twisted:
1130Leo
07-09-2014 18:59:00
 Re: MF 290 Fuel Bleeding Issue in reply to LJS30, 07-09-2014 12:27:36
Are you getting a really good stream of fuel out of the bleeders on the injector pump? If not, could it be your strainer on the fuel tank is blocked? I had a similar issue with my MF 40B, I took my air tank and blew from the line from the pump back into the tank, it seems to have solved my problem, temporarily at least. Going to pull the tank after the hay is done and completely flush it out.
