124 baler packer fingers
Any of you guys run MF balers? I've seen three 124s that the plunger side packer fingers have bent (and straightened) tines. I just bought a 124 parts baler that the shaft the fingers hang on is broken right at the drive crank. Seems consistent, so what's the cause of the problem? There are no grease fittings on the finger assembly so I wonder if it is seizing on the shaft and then twisting off? Ideas? Tim
