MF 135 light switch removal
Don.A NSW
New User
Hello
Is there a trick in removing the knob of the light switch ??, eg held on by thread requiring allen keys ??there is a hole in the knob
Or do you simply pry off ??
I am trying to get the wiring sorted so I can have High & low beam on headlights
Any advice welcome
Regards
Don
Hello Don,
If you insert the smallest pin punch you have into the hole of the knob, and push the small pin located in the shaft slightly, you will feel it move inwards. Now you can pry the knob off the shaft.
See how you go,
Evan.
