Hi Guys,
I'll be installing the power steering cylinder back into my friend's tractor this weekend (MF30 Industrial). See this post for more info on that if you like;
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=mf&th=151107
From my limited knowledge this is the same sort of power steering cylinder used in the 165's, 3165's, 175's and 30 & 31 Industrials.
Since this is not my tractor I'm not familiar with it.
Does anyone have the procedure for bleeding the air out of the power steering system once I get the repaired cylinder back in?
Where do I add fluid?
What kind of fluid should I use? It has a MF34 loader on it, if that's relevant.
Thanks,
DP
Thanks,
DP
