Hey Guys, I'd like to see if I could get your input on my MF 35 steering box rebuild. I downloaded a service manual but the steering box in it is not the same as on my tractor. My box has a plate on each side of the main housing with a threaded adjusting screw with a lock nut. My service manual shows a box that has one big plate on the left hand side that both rocker shafts can be removed through. My steering box is made where the rocker shafts each have their own hole to be slid out of. I'm trying to find the o rings and seals for the two rocker shafts as well as the upper and lower cone bearings for the steering shaft. I don't have the part numbers and don't have a clue to find a diagram showing them. What make of manual steering box do I have????
