Anonymous-0
We put the front end back on the 699. It continues to work intermittently. My next step is to check the solenoid valve. I got a "T" so I can monitor the pressure from the solenoid valve. I am wondering if the issue could be in the coil, I have seen intermittent coils before. My theory is the solenoid works until the coil warms up and then it fails open.
Anyway the loader is now off the tractor and on the round baler so I need to find a time the tractor can be down. I plan to remove the plate below the operators feet to get to the solenoid. Paul
