MF 235 1975
con-fused
New User
I can't seem to find which variant of this model I have. It has rectangular headlights down low at the front , planetary gears in the rear axles and a pre filter above the radiator. The ones I found on the web aren't the same. I need a new head light as they are down low where they can get damaged.
Maybe aftermarket lights? Tractordata.com said they made a vineyard and orchard models , maybe the serial number can tell you. Let us know what you find . I am looking at a 235 at the moment
It sounds like you have a 235 Orchard. These will have the planetary on the axle. Check to see if you have a fixed front axle with a power steering cylinder attached to the drag link. If you do this will be an Orchard model. This model is a better and heavier model than the standard 235. It is preferred by many because it does not have the steering issues of the standard 235. I would say the headlights are aftermarket as the rectangular headlights were used on the very late model 230 and 245. If it is indeed an Orchard model you have a very good tractor and will last forever if properly maintained. There is nothing built new today that will last as long as these tractors.
