Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Removing gas tank on 135
06-23-2014 03:59:45
I have a Massey 135 that I need to remove the gas tank. The tank is empty, I have removed the two bolts on the rear of the tank and I found one bolt on the front that I have removed. I still cannot lift it out. Looking for advice?
06-23-2014 04:08:36
 Re: Removing gas tank on 135 in reply to Jo1, 06-23-2014 03:59:45
Should be two at the front also, but the right front is harder to see.
Ray UK
06-23-2014 10:45:19
 Re: Removing gas tank on 135 in reply to Dieseltech, 06-23-2014 04:08:36
If my memory serves me correctly there is a carriage bolt with a spring and flat washers and a self locking nut located on either side of the top hose/thermostat housing.
If the tank is empty and all pipes are removed you may be able to lift the rear of the tank and slide the tank to the rear to clear the front bolts as the bolts locate in slots on the underside of the tank.
06-24-2014 03:43:09
 Re: Removing gas tank on 135 in reply to Ray UK, 06-23-2014 10:45:19
Thanks, I was able to get it out but I"m not sure how I will be able it get back in. The two bolts with springs are gonna be difficult, especially the one on the right.
06-24-2014 06:13:10
 Re: Removing gas tank on 135 in reply to Jo1, 06-24-2014 03:43:09
When your ready to install take 2 7/16 inch open end wrenches and put the open end under the top of carriage bolt where the tank goes and when you push the tank forward the 7/16 will fall out and allow the spring to pinch the tank.
Ray UK
06-24-2014 11:07:58
 Re: Removing gas tank on 135 in reply to 2tractors, 06-24-2014 06:13:10
I had forgotten the spanner trick for reassembly, but then it was over 40 years since I was working on these tractors regularly.
