1080 Ferguson Lift not working
Pulled the top off to fix the slip coupler, put top back on, and from what I can tell everything is right. Filled it with fluid and now the lift want work. Anybody got any idea as to what I may have done wrong, worked perfect before I removed the top. Thanks
Hi Chris,
Make sure that you have engaged the standpipe in the pump. To check this remove the two bolts that secure the cap plate at the front of the hydraulic cover and make sure that the cap is sitting 'square' and that the pipe is retained at the bottom.
DavidP, South Wales
We'll I haven't put it under a load test yet, gotta get it put all back together, but it works, the O rings on the tube were cut , so I am guessing they weren't sealing properly. Thanks for the info and help,
