TractorLinks.com
Show Parts for Model:
1080 Ferguson Lift not working
Chris Roberts
06-22-2014 18:04:51
Pulled the top off to fix the slip coupler, put top back on, and from what I can tell everything is right. Filled it with fluid and now the lift want work. Anybody got any idea as to what I may have done wrong, worked perfect before I removed the top. Thanks
DavidP, South Wales
06-23-2014 00:33:43
 Re: 1080 Ferguson Lift not working in reply to Chris Roberts, 06-22-2014 18:04:51
Hi Chris,
Make sure that you have engaged the standpipe in the pump. To check this remove the two bolts that secure the cap plate at the front of the hydraulic cover and make sure that the cap is sitting 'square' and that the pipe is retained at the bottom.
DavidP, South Wales
Chris Roberts
06-23-2014 08:49:35
 Re: 1080 Ferguson Lift not working in reply to DavidP, South Wales, 06-23-2014 00:33:43
I will double check that this afternoon but I am sure it's sitting all the way down. Thanks
Chris Roberts
06-24-2014 08:33:21
 Re: 1080 Ferguson Lift not working in reply to Chris Roberts, 06-23-2014 08:49:35
We'll I haven't put it under a load test yet, gotta get it put all back together, but it works, the O rings on the tube were cut , so I am guessing they weren't sealing properly. Thanks for the info and help,
