Overview of the draft control on the MF-65
Rkh
can someone explain the workings on the draft control & response control-new at using this? can you use it to control the pressure on the back blade like when snow plowing on a driveway with 2b stone so your not digging up the stone?
Draft control only works when you're pulling an implement hard. There has to be a lot of pressure on the top link.
For plowing snow, you just need to use the position control. And practice a lot.
move the draft lever all the way to the top leave it there unless you are using an implement that creates down pull (draft)ie. plows,subsoiler etc. when using the draft lever the position lever has to be in the full up position,same with the position, draft lever stays in the full up position when using the position lever, the position lever is the one used to control the lift for disc harrow,blades, mowers etc. the lever on the right side of the transmission controls the rate of drop speed for both levers
