hi,
I'm curious about the workings of my 3 point hitch.
I recently bought a non running mf 204 and have finally got it running. The 3 point hitch works, but something funny is going on with it. I hook up to my box blade, and it doesn't want to lift the blade. I put it in gear and rev the engine but still no luck. It seems that if I step off the brake and let the tractor move, it will lift the blade. Is the pump on this tractor attached to the engine in a way that it will only work when the wheels turn? I'm used to a tractor that the 3 point hitch works anytime the engine is turning.
Also does anyone know what hydraulic ports are under the cover plate on top of the lift arm cover? Got pictures?
Thanks
Dave
Thanks
Dave
