1952 Ferguson TO-30
Anonymous-0
My tractor has been converted to 12 volt. I can crank it by jumping it off, and the battery is fine only 2 years old. I tried another battery too. When I disconnect the jumper cables the tractor dies either immediately or after 20 seconds or so. What could be the problem.
most likely a croded connection
my bet would be the frame ground
or the positive starter cable
if you are using the repacment battery clamps the bolt downs onto the cable can also be a problen
