MF 65 Clutch
tinman7t7
New User
Help My MF 65 tractor will not let me disengage the clutch. When I push on the clutch the spring that I usally feel is gone and it will not disengage. I don't hear any different noisies. My MF65 has the multi power transmission with a dual clutch. It seams like the clutch is holding good I just cant disengage it ???????
If you are lucky the clamp has slipped on the shaft for the clutch free play adjustment. If you are not lucky the release bearing has stopped turning long ago and ground away the lever ends along with the bolts, would be worth a look through the bottom plate opening.
Could the fork screw that secures the fork to the shaft have sheared on the shaft. If the bearing was bad and the fork ground down shouldn't I have been able to fell that kind of ware through the pedal prior to this. Im only going off a shop manual diagram for my tractor Ive never had it apart before
