TractorLinks.com
Show Parts for Model:
Re: 1155 pto issue
MF rules
06-07-2014 11:30:58
10/4 on that. That noise may go away after its used awhile. I'm suspecting that the rear shaft bearing had rusted alittle due to sitting and not being used. Your rear oil seal may be letting moisture in and hence it rusted the rollers on the bearing. I've found that best policy is to leave the pto engaged and let it coast when not being used. If you need to hook up the pto just shut tractor off. With the pto always coasting the bearing is always rolling in oil and won't lock up. Good luck. Luke
