Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1155 pto issue
MF rules
06-06-2014 20:27:01
Why are you messing with that lever!? We always leave ours engaged......who cares if they coast while running!? Doesn't hurt a thing!
derekyakelashek
06-07-2014 09:20:07
 Re: 1155 pto issue in reply to MF rules, 06-06-2014 20:27:01
i just bought the tractor and didn't even know what that lever was for until I needed the pto to work. for some reason when I needed it it would engage but now it works fine. although it sounds noisy
MF rules
06-07-2014 11:30:58
 Re: 1155 pto issue in reply to derekyakelashek, 06-07-2014 09:20:07
10/4 on that. That noise may go away after its used awhile. I'm suspecting that the rear shaft bearing had rusted alittle due to sitting and not being used. Your rear oil seal may be letting moisture in and hence it rusted the rollers on the bearing. I've found that best policy is to leave the pto engaged and let it coast when not being used. If you need to hook up the pto just shut tractor off. With the pto always coasting the bearing is always rolling in oil and won't lock up. Good luck. Luke
