timing and dwell meter
Can I use A timing light to set timing on a Ferguson 35 , what is the timing suppose to be also can I use A dwell meter to set the points
yes, but if you will set they points to proper gap first then static time it with a test light you will be real close for a tractor
A dwell meter is really only useful when there is a window and a screw to set points.
It is much easier to set tractor points with a feeler gauge. The timing should not change if the points are set the same every time.
