Anonymous-0
Thank you 25Twin and Dieseltech for the insight.Just went back to the operators manual and it states that if you have trouble shifting the standared gears then shift the multipower into low before shifting gears.
Now one mare question please, when the multipower is in high I think I can hear the gears on the multipower pump and the lift pump meshing together. The ticking noise is most noticed when the engine is on idle and when it is shut off. Is this normal.
Thanks again as I was dreading splitting the tractor again without being able to use it.
