Anonymous-0
I have rebuilt the multipower clutch assy., shift control valve, replaced the drive clutch and adjusted the clutch release fingers as directed in a ITT manual.
Put everything back together, fired it up and when the multipower is in Hi I cannot shift into any gear unless I push the clutch pedal all the way through the PTO clutch.
If the multipower is in low it will shift without any problem.
Can someone tell me what might be my problem.
This tractor has been a royal pain and a learning experience since its purchase 18 months ago.
