Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: mf220 backhoe
Masseynut(Australia)
05-31-2014 15:01:14
Hello, The dowel pins are designed to correctly locate the "paddle" onto the shaft. The cap screws are then tightened down to lock it there.
The dowels are fitted with the threaded section protruding, so as a hex nut can be used to extract them from the shaft on disassembly.
If your dowels have worked their way out of the shaft, they may need replacing, but check the condition of the bores in the shaft as well.
Normally, these dowels are fitted into position by screwing on a nut flush with the top of threaded section and driving them in with a brass hammer. If they tap in easily, they could work their way out as in your case. Loctite may be advantageous, if they are not too worn. The cylinder is cast steel, not iron, and can be built up with mild steel electrodes and then turned down to size. Also check that there is no excessive clearance between the shaft and the top and bottom housings and always fit new shaft "o" rings. Hope this helps, Evan.
andrewb
05-31-2014 16:28:35
 Re: mf220 backhoe in reply to Masseynut(Australia), 05-31-2014 15:01:14
Evan,
Many thanks I believe u have solved my puzzle and extra thanks for refit tips.
Copyright © 1997-2015 Yesterday's Tractor Co.
