Yesterday's Tractor Co. The Right Parts, Right Away
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
mf220 backhoe
andrewb
05-31-2014 11:41:59
47.55.117.128
I need help. My rotating cylinder was leaking badly. I have removed it and found the cylinder badly scored by the dowel pins on the shaft. See photo. My question is about the dowel pins. What do they do and are the inserted right way round. It makes no sense to me as if I put them back the same way they will score the cylinder again. By the way iwas looking at wwwabbits thread. It took 20 mins to remove the cylinder and an hour to break it down in the garage. Much easier than I thought. However I am now at a standstill because of the pins. Can anybody help
[Reply]   [No Email]
Masseynut(Australia)
05-31-2014 15:01:14
124.186.242.179
 Re: mf220 backhoe in reply to andrewb, 05-31-2014 11:41:59
Hello, The dowel pins are designed to correctly locate the "paddle" onto the shaft. The cap screws are then tightened down to lock it there.
The dowels are fitted with the threaded section protruding, so as a hex nut can be used to extract them from the shaft on disassembly.
If your dowels have worked their way out of the shaft, they may need replacing, but check the condition of the bores in the shaft as well.
Normally, these dowels are fitted into position by screwing on a nut flush with the top of threaded section and driving them in with a brass hammer. If they tap in easily, they could work their way out as in your case. Loctite may be advantageous, if they are not too worn. The cylinder is cast steel, not iron, and can be built up with mild steel electrodes and then turned down to size. Also check that there is no excessive clearance between the shaft and the top and bottom housings and always fit new shaft "o" rings. Hope this helps, Evan.
[Reply]  [No Email]
andrewb
05-31-2014 16:28:35
47.55.117.128
 Re: mf220 backhoe in reply to Masseynut(Australia), 05-31-2014 15:01:14
Evan,
Many thanks I believe u have solved my puzzle and extra thanks for refit tips.
[Reply]  [No Email]
Inno
05-31-2014 13:43:51
174.89.118.86
Having never taken mine apart, I can't be much help but have you looked at the diagram on the agcopartsbooks site? http://agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/651157 to see if helps make sense of it?
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
