175 hydraulic cooler
21 hunter
New User
I have a hydraulic cooler leak on my 175 diesel. Having a hard time finding one. Does anyone know any good sources for these. I have it bypassed for now, was also wondering how hot the fluid would get without it. No loader work, just 3point and an implement cylinder.
May not get hot enough to need it, early models did not have a cooler or the filter in front. Late 165 and 180 cooler should also fit if you are checking salvage yards.
Thanks, I might mount a tee with a temp gauge in the hydraulic line to see what the temperature runs whil working.
I think the hydraulic clutch packs (Multi-Power & IPTO) are what really makes the oil hot. The early M-P tractors didn't have oil coolers. It will probably be fine if you don't have IPTO.
I have a late 65 and an early 165 that are both set up that way. Neither one has an oil cooler. I previously had a later 165 with M-P and IPTO that did have the cooler.
