massey Ferguson 175
is it possible for your transmission to slip if you overfill it with fluid I was pulling a bean drill and made for five passes and my tractor would just almost stop never made any noise or anything and I seen that I added too much transmission fluid could that cause a problem.I"ve never had any problems beforeafter I let the tractor cool down several hours went back out it would move fine
I could see that happening if enough oil leaked through into the bellhousing and got on your clutch. Check the weephole underneath to make sure excess oil can escape.
Dont think fluid is the problem I drained some out still same problem tractor wont hardly pull itself. Motor runs fine wont pull itself in high will go half speed in lo but only in first
