RedBarnNate
Hello there!
We are in the middle of a rebuild on a MF165 with SN: "SDW643007085," and a stamped # "29D1692" on the LH side of the motor just behind/below the rear-most exhaust manifold hole. There is also a "C" stamped below the "29D1692." I was told this is a 4.203 Diesel with Direct Injection. Does that sound correct?
We are rebuilding the motor, and noticed the below pictured damage to the camshaft. Is this normal for a tractor of this age? Does the camshaft need to be replaced? If so, are they available for purchase? Thanks!'
