mf 202 hdraulic levers
Jack-Iowa
anyone know what would cause the leaking of hydraulic fluid from the e bottom of the valve ttat controls the hydraulic lift of the bucket.seems to be at the bottom of the valve ,I imagine it is a gasket or rubber seal at the bottom where the four bolts are.
any help or clues?
thanks
I had to do some modification but I installed a Prince hydraulics dual control with float.
Could you post some pics of your setup to see if it's similar to what I have?
Here are a couple from mine. This was converting to a fully hydrostatic power steering system. The loader controls were not the focus but you can see them and the adapter built for the return line.
so you did that to get better power steering?looks good but way beyond my capabilities.
can you try posting that link again so I can get the part number. or even what section it is in as I lloked thru th eagco on the 202 and could not find the the lever control valve.
thanks again and have fun with your project.
I did that because the power steering on my tractor had been disconnected long before I got it. Manual steering with a front end loader does not work! I kept breaking steering parts. Replacement parts for the original power steering would have been expensive and hard to find. I decided an upgrade was in order.
You won't find the control valve when you look up a 202 because the loader and backhoe were not part of the original tractor. They used a few different ones. My loader is a Davis 102 and the backhoe is a Davis 220. Go to www.agcopartsbooks.com and search for Davis. You should be able to find it. There were two different control valves listed with Davis 99 loader, one might be similar to yours. Outside of that, without knowing what model your loader is, I can't be much more help.
ok I have the 101 102 loader on it .here are pics of the controls in question.
is it possible that it could drain the hydro fluid from the system as now I have no hydaulic lift or back hoe control. or maybe the pump blew out.any way to test or just fix hte leaks and see what happens and refill the hydro .
thanks for any help.as need to get it working.
