Dopp Creek
On my 65 the travel clutch now works but the PTO will not disengage. I set the clutch pedal linkage per the book to no avail. I pulled the inspection cover and measured the clearance of the adjusting screws; two were spot on .080" and the third was .086" (using number drills as gauges). I set that one to .081". Could that one being out of adjustment be enough to not release the PTO?
Second question, the 1/4" hole aft of the inspection cover, is that the one that should have a cotter key in it? I found a sheet metal screw wrapped in pipe tape stuffed in there and drained about 1/4 cup of gray liquid. What does that indicate?
I certainly appreciate all the help with this! Tim
