hey guys ran into another problem while bringing this thing back for the dead. my bellhousing is filling up with oil and filling my starter up.i was thinking the rear main but my engine oil level hasn't dropped at all. so then i started thinking input shaft seal so at this point i have the tractor split in my drive way but am not sure where to start. the oil smells like gear lube to me. isn't the trans and hydraulic fluid the same? or does the trans use gear lube and the multi power hydraulic oil? is so do i just pull the multi power unit off to get the the input shaft seal? any help would be great so i get this thing back together asap before i start getting even more complaints .
thanks
jason
thanks
jason
