MF35 steering dilemma
I am starting to think this tractor was a conglomeration of 3 or more tractors. All the OEM parts I order are not the correct pieces for mine. This time its this steering shaft. All I need is a seal kit or bearing kit. I can't find its equal as any MF35 equipment. Can someone help me with what I need?
AGCO shows TO 35 and after #231862 MF 35 to use the same seal--#1751702M1. Was the seal letting oil come up steering tube and out around steering wheel and running down dash?
If you look closely you will see that that is not the original steering box. Looks like someone changed it over to hydrostatic steering.
No. I just saw a thick meal seal, which looks like there is felt inside, was coming out from the top of the tube once I took the steering wheel off. So i took the tube off to see a rusted shaft and water coming out as well as blackish oil/sludge. So, after doing what I could to clean it all out, I need seals to put it back together. There was also a bearing with no race that looks like 1850526M91. But don't ask me what it was doing in there.
There's a diameter difference with the ps model and the manual shaft with the manual being smaller around, make sure you didn't receive manual parts.
Does anyone else have an idea what what I need to finish this project? I also noticed a lot of MF pictures show a 4 bolt tube over the shaft where mine is a 3 bolt. Does that define anything in terms of what I would need? Thanks
